Epoxy primer scratch before high build
Tony1968
2,313
5,100
NW Indiana
I hit this with 80 grit. Is this enough to hold the high build primer?
Been in epoxy for months so it's cured obviously.
Clean up and spray or ?
Summitracing products
No specific sandpaper recommended and I've searched. I've read between 80 and 220 to scotch Brite. Nothing definitive
Thanks
Flyers9928
597
1,515
South Central Pa
80 grit is more than sufficient, I normally use 180 or 220. Hell a red scotch brite is enough!
Tony1968
2,313
5,100
NW Indiana
Laid down ok. I guess. A little peal but I think it's my fault because I'm doing it lefty and have bad coordination. 3 coats. Block sanding soon
57 Handyman
338
388
Looks good! Now, hit it with some contrasting paint or guide coat to help in your block sanding to ensure you get surfaces flat as can be. I like to start with 220-grit and end up at 600 before sealer. I like using this pad for block sanding since it fits comfortable in your hand and uses hook-it disc sandpaper.
As always, take your time!
08Malibu
1,447
3,386
North Jersey
When block sanding, it’s best to use a proper block. That one is not it. I only use that for taking texture out on new parts. I used to use dura blocks, but recently got into using acrylic. The hard acrylic cuts way flatter.
Tony1968
2,313
5,100
NW Indiana
I've got a durablock kit but also read about using a paint stick for sanding Can't afford acrylic blocks.
But I can be creative with some harder foam or whatever
melloelky
4,135
9,484
mass
don't di$count the dura blocks,they're a lot better than what i had when i started.they work.
08Malibu
1,447
3,386
North Jersey
You can easily make your own acrylic blocks. You just need to cut a piece to the size needed.
