Hello!
I am looking to install a new exhaust system on my 78 Lemans, and I need some help, as my thoughts are stuck and I can't make up my mind. Here's what I am stuck with:
Engine is a "mild performance" 350cui Chevy Small Block with a 600cfm Edelbrock Carb.
Options for the exhaust system:
Headers (full length): no chance. on the passenger side, not a single set I bought fit the chassis. they always touched. shimming the engine or trying different engine mounts didn't help either. also: none have thick tubes to keep the heat within and i don't want to wrap them.
Headers (shorties): a good solution IF the headers go imediately downwards at the rear cylinder. why I don't like the idea: most of the time the sparkplugs are difficult to reach. also: none have thick tubes to keep the heat within and i don't want to wrap them.
Log Manifolds: good access to the spark plugs, they keep the heat inside, but not a very good exhaust flow.
Ram Manifolds: better exhaustflow, keep the heat inside, but no idea if they will fit past the frame below the engine. Has anybody ever done this here on a 78 G-Body without modifying the chassis?
Modified Log Manifolds: (as made by BRZEZINSKI Racing Products) Improved exhaust flow over stock manifolds but very expensive. Does anybody have any experience with their products?
Any advice to get me un-stuck is most welcome!
