Extended rear wheels studs replacement
Olgambler84
Dec 26, 2018
68
65
Any clues on what should be done, what needs to be taken apart so I can hammer in my app extended wheel studs. Still have drums
I'm going to say the easiest way would be to pull the diff cover, cross bolt and c-clips, slide the axles out, and do it on a press if you have access to one. Otherwise, I'm sure it can be done on the car, but I can't see it being much fun.
bracketchev1221
1,410
1,647
Depending how long they are, you may be able to remove the brake shoes and get them in from behind. I would also try to get a long lug nut and tighten them in slowly.
Olgambler84
Dec 26, 2018
68
65
While the diff cover is off, any suggestions on what else I could/should do while it’s open?
Tuffregal83
639
1,150
Lockport, Il
I forgot what length have but was able to do it without pulling the axle
shoedoos
406
403
Not that I have done this, but what if you drilled a hole in the backing plate so you could get the longer stud through from the back with a magnet/extension?
And don't drive the stud in.....draw it through the axle pad with a long/oversize socket/sleeve and the corresponding wheel nut.
In my imagination, you would only need a single hole in the backing plate then move the axle round to install each stud. Once complete get yourself a rubber plug and away you go....
Olgambler84
Dec 26, 2018
68
65
Thought about drilling the back plate but wanted to see if other ways were possible
Tuffregal83
639
1,150
Lockport, Il
Mines stick out an inch with lug but also, how did you go about it?
I think I had the brakes off pounded out the old ones with a hammer installed the new ones with a couple thick washers and ran old lug nut down to pull it tight you don't want to use the same lug nut for every stud Maybe do 1 lug nut for every two studs
