No power at fuel pump, powers on with wiring from the pump straight to the battery...Yes see if you have 12V at the pump. If not figure out why not. If yes then the pump crapped out.
I have an Edelbrock pump, bought it in October 2021... It's good, just no power to it..Those little Mr Gasket/Edelbrock pumps seldom last over a year or so. Reviews on them suck big time, and my boss had one on his Chevelle...lasted about a year.
I have used a pump made by Facet/Purolator several times, from 1981 all the way up til currently. They're more expensive, but quieter and lasted longer than I owned the cars they were on
Pic for reference, they make many versions of it...
I look into one of the references you mentioned.Those little Mr Gasket/Edelbrock pumps seldom last over a year or so. Reviews on them suck big time, and my boss had one on his Chevelle...lasted about a year.
Fuel pump power wire runs to this aftermarket fuse box mounted on the passenger side front fender in the engine bay...
The power wire bolted on the this fuse box has no voltage either...
To the alternator, see the YouTube video I uploaded and shared.Isn't that stud on the bottom of the fuse block where the battery hot is connected to it? Where is the other end of that wire connected?
