F 41 suspension upgrades
ck1984
Sep 19, 2021
52
24
8
according to my vin I already have the F41 upgrade, which i gather is;
1. those front frame to crossmember braces?
2. an added rear sway bar
3. thicker front sway bar
4. and as per vin; F41 (SUSPENSION,FIRM RIDE HANDLING,FRONT AND REAR), I assume that also means higher rate springs?
Corrrect me if im wrong.
So if that being the case what are the obvious suspension ride and handling upgrades?
another thread mention boxed in brace connecting front frame rails?
same thread also mentions a similar brace or hitch in back?
what else?
Ive already replaced rear shocks with monroe sensatracs and fronts with ACDelco 520-179 Advantage Gas Charged
abbey castro
1,046
1,313
Harker Hts TX
"Correct Me If I Wrong" You men your SPID label not your VIN. VINS do not have that info on them. I added a home made rear bar, rear LCA brace to UCA brace upper shock frame bar. I felt the change with these additions.
  • Informative
88AZSS
435
1,098
Mesa, AZ
There is also:
"Grand Prix bar" which ties the front rails together. Found on Grand Prixs and can be used with the F41 jounce bars you have now.
Fender to Radiator Support bars, not sure what these came on stock. My 87 Monte SS did not have them originally.
Radiator X Cross bars. Sits ahead of radiator on support. Found on Buicks I believe.
X Brace behind rear seat. I believe this was a Grand National thing but there are plenty AM options now.
All of these plus the above mentioned items are easily added and make a world of difference.
  • Informative
86LK
1,965
2,030
what else?
you're also forgetting the underhood stuff like; firewall to fender, and, fender to core support braces.
69hurstolds
8,185
17,568
??? How exactly does the VIN verify RPO F41 on (I'm assuming) a Brougham? The only thing the 84 VIN can tell you is the manufacturing country, manufacturer, model/car line, seat belt type, engine type, and manufacturing plant. Along with the plant sequencing number.
You either have it or you don't. And it's not standard on any Olds G-body in 84 unless you have a Calais. The only way you can tell if F41 is on your 84 Olds G-body from the VIN is if you see K47 in the VIN. It appeared only when the Y78 RPO "option" for Calais is checked on the dealer ordering sheet. It actually changed the VIN to reflect Calais. While the VIN doesn't explicitly say you have F41, it's simply deduced that it does because F41 is included with Calais.
The F41 consisted of a tad stiffer spring rates, faster rate steering box, HD shocks (Hurst/Olds had Air Shocks in rear for 84), and the sway bars as you mentioned.
