F Body Pedals in G Body Cars
Firetruck1
Firetruck1
Nov 1, 2017
70
110
#1
I read in several closed post from around 2016 (using the search function) you use f body pedals in the g body for manual transmission swaps. I am about to do this in my 88 month carlo with a t56 and third generation pedals. What work so I need to do to these pedals to make them work?
Any pictures, advice, explanations, links or wisdom would be much appreciated.
Thanks in advance, Michael
TURNA
TURNA
6,591
8,476
Socialist NY
#2
I'm not sure about the FBody pedals but I did use an FBody clutch master
SickSpeedMonte makes a great pedal setup that is a direct bolt in for a good price
http://sickspeedmonte.com/Pedal.htm
airboatgreg
airboatgreg
1,415
1,307
I have seen that also and using a master/slave hydraulic clutch cylinder. I went with the regular pedals and a manual clutch when I put my Muncie in. The pedals fit nicely and there is a couple options for the clutch fork. The holes on my 82 El C were drilled for the bell crank so you may want to look at your frame. If not drilled the F Body stuff may be way to go
Firetruck1
Firetruck1
Nov 1, 2017
70
110
#4
Turna, 300 is not too terrible. I do like that it provides a reinforced location for the master cylinder. I'm curious on how to combine the G body upper bracket and the F body pedals as i read in other threads.
Greg, this will be hudraulic so I only need the firewall holes, nothing frame side.
pontiacgp
pontiacgp
Canadian Prime Minister
Mar 31, 2006
24,191
9,405
Kitchener, Ontario
#5
I used the G body pedals and the G body pedal housing and cut the brake pedal pad for a 3 pedal car. I used the bolt from the 3rd gen F body pedal housing to hang the F body clutch pedal. For the clutch pedal I cut it and added 3/4" to it and positioned it so it would sit closer to me so I could slide my foot behind it cruising down the highway. I used the F body master and you need to put a doubler on the firewall or the firewall with crack. If you are going to use a hydraulic throw out bearing you wil need to put a stop for the pedal so you do not overtravel and damage the throw out bearing. I used an appliance adjuster with a nut on each side of the firewall for a pedal stop.
Firetruck1
Firetruck1
Nov 1, 2017
70
110
#6
Ponti, great description. Do you have some photos by chance?
pontiacgp
pontiacgp
Mar 31, 2006
24,191
9,405
Kitchener, Ontario
#7
I don't but it isn't difficult to do, Just tack the 3/4" extension to the clutch pedal and put the pedal assembly in to see if it is the location you like.
airboatgreg
airboatgreg
1,415
1,307
The standard shift is worth the effort to me as long as it is not a daily driver. Driving the El C brings out the kid in me:)
Cutlass400hp1986
Cutlass400hp1986
106
139
Oaks, Pennsylvania
#9
I used third gen camaro clutch pedal, what I did was grind off the camaro clutch pedal assembly, and welded it to the automatic pedals and then swapped the camaro brake pedal arm over to the original pedal as well since the pad is smaller. Used third gen clutch master and slave cylinder with custom braided clutch line. But I’m running world class T 5 . You running a t56 would be internal slave but same other stuff.
ssn696
ssn696
3,401
2,169
New Mexico
#10
Photos would be most welcome.
Similar threads
