Factory wiring a one wire alternator?
ham1974
240
66
I have a one wire alternator that I bought from a local speedshop. How should I hook this up with the these plugs? the plug looks obvious and there is another wire with an eyelet but what about the red one?
factorywires Wiplug?
565bbchevy
9,614
12,683
Michigan
A true 1 wire alternator only needs the power feed wire that comes from your battery and would go to the back of your alternator and a good ground, and you would typically have to rev the engine to get it to start charging
This would also be a good time to up size your power wire especially if this is a higher amp alternator.
ham1974
240
66
So I ran this set up in an S10 I ran a wire from battery to the nut on back and also a wire back dis block on firewall. I was putting the battery in trunk on this car.Can I use the factory wires?
565bbchevy
9,614
12,683
Michigan
It depends on how your 1 wire was built some can be used in either a 1 or 3 wire application.
I have my battery mounted in the trunk and the positive runs up to a remote solenoid mounted on the heater case and off of that I have a positive wire that runs to the front of the car to a distribution block and that is where my alternator gets power from.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
Like 565bbchevy many of us who have the battery in the trunk use a ford style solenoid in the engine compartment and have upgraded the factory wiring. I run an 8 gauge wire from the alternator to the solenoid,
melloelky
4,161
9,568
mass
any part store,get it for a 1985 ford f-150.they're short money.
  • Informative
