Top of my head:The OBD1 I got read 4 codes at one point. I took it for emissions last year really high HC and CO. I changed plugs, 02 sensor had an oil change. I rebuild the carb, changed throttle position sensor, sent it off to be live tested it came back and I was told it was running great. I just ordered a new cat and installed it last Friday before the second emissions test. I had the radiator rebuilt recently. The codes reading are
12-Diagnostic mode; no distributor signal to Electronic Control Module; System PASS
21-Throttle position sensor (TPS) - signal voltage to high
35-Idle air control (IAC) system problems - can not set desired RPM or idle speed actuator (ISA) carbureted system problems
45-Rich exhaust indicated (Left side on dual oxygen models)
Code 12 - just means the diagnostics are being read from the ecm. No action necessary.
Code 21 - has the trans acted funny at all? Often this would be a poor electrical connection, damaged wire inside the insulation, something of that sort. I'd check the plug and wiring. Aside from a visual fail for a light,, I don't see that being an issue with the emissions.
Code 35, is that recent or before doing the carb? With things being unplugged for rebuild the IAC resets/relearns by being driven around a bit.
If your idle speed is high due to a vacuum leak it will trigger the code 35.
When replacing the carb, did you replace the old rubber lines, or just slip back on the old ones? Could have a vacuum leak somewhere.
Vacuum leak could cause the computer to call for a/f mixture to be off leading to some issues.
Code 45 would be your o2 sensor reading too little oxygen as I was guessing initially.
Old timer trick: spray around the base of the carb, and at various junctions with either carb cleaner or wd40 with the engine idling. If you hear the rpm race momentarily, that's because the vacuum leak pulled in some spray and let the engine race a little meaning you're in the neighborhood of the leak. Works on intake manifold, carb gasket, etc.
