This my second time changing it
I clean all the connection even tho they wasn’t in bad shape but still nothing
Anybody have this similar problem this the switch I had in it before
Thanks I thought it would be simpleOooh, oooh, I have had a problem like this before. On the fan motor, there will be a thick Purple wire that powers the fan. This is the B+ to the motor. There is a bare ground strap that goes to the fender as a body ground. Where this bare strap screws to the motor, there is a male spade terminal that has a thick Black wire attached. If this thick Black wire is disconnected, the fan will run in all speeds but high. It could possibly be a coil ground for a high speed relay if there is one equipped.
Check to make sure this wire is connected and the connection point is corrosion free. Hopefully others can chime in with the Black wires exact purpose.
I found the red wireThere is a 10 gauge red wire that feeds this (yellow circled) relay which is the feed for the high speed. There is a connector on the passenger sided near the front of the valve cover that has the red wire. As fleming442 that red wire comes from the fusible link attached to the B connection on the starter. It is hot all the time.
It could, may also be the blower motor resistor which is connected to where the blue, brown, yellow and green wires which look a little corroded.
