So i just bought my first cutlass and so far i have to say, it love it just as much as I thought I would.
My only problem is the motor and transmission combo are a little confusing to me. and I believe it is the root of my small problem.
first off, its an 88 cutlass supreme, the body and suspension are bone stock I'm pretty sure. the exhaust system is true duals with a cherry bomb on each pipe and they are connected to stock manifolds.
that's all I know so far and here's the problems I have come across.
1. the motor is out of an 86 monte carlo super sport, 305 h.o. I haven't checked block casting because I haven't been able to find one yet, but it is painted orange from the factory it looks like, so I will take that as evidence the gentleman wasn't lying to me about it. also it does have center bolt valve covers like a chevy 305 would
is there any way to visually see a difference between n olds 307 and a chevy 305?
2. the transmission looks to be a 2004r from an olds, it's got those universal bell housing bolts( the three holes at the top of the bell housing are not even bolted to anything, and I think this transmission is the root of the 3rd problem.
3. the car runs great and sounds exellent but it wants to shift at like 1500 rpms into second and it's like a long drawn out shift with no power to it at all. and it seems to want to shift into 3rd at just under 2000 rpms. it's like something in the motor or the transmission wont allow the car to build up any power before it shifts....really annoying
It WILL, however, shift manually just fine it seems.
Also, when I hit a bump, big or small, the back of the car sounds as though the frame is not attatched to the rear shocks, which look to be in o.k. condition. its pretty obnoxious to drive with friends in a freshly painted car and then hit a tiny bump and sound as though you just lost a major rear end part lol
can anyone give me some things to troubleshoot? I am brand new to these forums, so let me know if you need more info or anything of the sort.
sorry for the long post and thanks in advance! 🙂
