did you adjust the TV cable according to the book procedure for a throttle valve and not a kickdown cable? it's a common mistake, and they're completely different
Bossman317 said:O.k.
sorry about ther late update, I ended up having to go down to west virginia to shot crete a coal mine. fun fun...it was 4 feet tall and I'm 6 foot 3 lol
anyway, I finally got under the rear end and found that my dual exhaust was banging against the diagonal bars that connect to the rear end. I tie wired them back to prevent movement in that spot and all is well, tooka test drive and not a peep from the rear end on bumps...very excited about that.
I also had quite a bit of trouble finding tdc for timing because I found out I have no timing pointer what so ever. so I have been doing the #1 plug method. it's close, but still kinda sluggish on WOT or Half throttle for that matter and it take a second to start. but it runs for the time being.
Also, is it possible to stretch your tv cable? I think thats what happened to mine. It shifts a little high and at WOT it wants to drag the shift out like it doesnt have enough pressure to kick into 2nd gear. I usually dont get out of 2nd gear because of where I live so I dont know about 3rd or 4th.
It's a 200r4 by the way.
Not sure where to start troubleshooting. I'm going to pull the cable from a 87 iroc camaro and see if I can swap therm and fix the problem. it has a 700r4 and 205 HO so it wouldnt be a problem right?
