First Dyno run on my 383.
Discussion in 'Photos, Videos, etc.' started by ZZ4CutlaSS, Oct 27, 2016.
  1. ZZ4CutlaSS
    ZZ4CutlaSS Master Mechanic
    Jun 11, 2011
    412
    62
    Minnesota
    . First Dyno run a engine I put togther. I started with a GM Performance HT 383. Added a High Volume oil pump, windage tray and Mildone 7qt oil pan. Comp Cam XR288HR 288/294, Lift .520/.540 Camshaft with GM Performance LS7 lifters. Comp Cam double roller timing chain and .080 thick wall solid push rods. Comp Cam 3 peice timing cover. Up top AFR 1054 210cc CNC ported Aluminum heads. Compression is around 9.5-1. Arp rocker studs and Cam matching springs locks and retainers. Finished off with Comp 1.5 ratio Magnum roller rockers on the Intake side and 1.6 on the Exhaust. That added 10hp on the Dyno. Edelbrock Vic Jr Intake port matched by me. Used all Felpro gaskets and ARP fasteners. SFI Approved Balancer and Flywheel. Spark by MSD billet Dist and wires. For Dyno only I used my Holley 850 HP XP then Later to Terminator EFI. Plan is to add a Pro Charger that's why I kept the Compression low. It Made 490hp at 5,800 rpm and 462 ft lbs of torque at 4,700 rpm on 92 octane fuel and 36 degrees total timing. Thanks for Watching.
    • Like Like x 4
    • Winner Winner x 2
  2. pontiacgp
    pontiacgp Canadian Prime Minister
    Mar 31, 2006
    21,735
    2,923
    Kitchener, Ontario
    nice, you have to be happy with those numbers....:)
    • Agree Agree x 2
    • Like Like x 1
  3. ZZ4CutlaSS
    Jun 11, 2011
    412
    62
    Minnesota
    Thanks I was so nervous and more Excited I took it home in one Peice.
    • Funny Funny x 1
  4. pontiacgp
    Mar 31, 2006
    21,735
    2,923
    Kitchener, Ontario
    I would be too, I've seen a few new rebuilds blow up. Yours sounded really good and great numbers on the A/F mixture with that carb.
    • Like Like x 1
  5. autonaut
    autonaut Greasemonkey
    Feb 22, 2014
    210
    17
    Nice build and great numbers. Congrats on your new engine:)
    • Like Like x 1
    • Agree Agree x 1
  6. Opie Knievel
    Opie Knievel Whiskey Fueled Midnight Mechanic and Moderator
    Staff Member Moderator Silver
    Sep 6, 2010
    1,502
    748
    Brodhead, Kentucky
    Hell yeah. Good strong numbers. You're so close to 500hp you can taste it. Lol.
    • Funny Funny x 1
  7. ZZ4CutlaSS
    Jun 11, 2011
    412
    62
    Minnesota
    Yeah me too kinda kept that in the back of my mind. We had to play with it for awile to get it at a safe level. We jumped like 5 numbers on the jets and up a couple sizes on the air bleads. Chuck the Dyno master was in love with that carb.
    • Like Like x 2
  8. ZZ4CutlaSS
    Jun 11, 2011
    412
    62
    Minnesota
    Thanks Man...I built it earlier this year. It pushed my 84 cutlass into the low 12's in the 1/4 mile.
    • Like Like x 2
  9. ZZ4CutlaSS
    Jun 11, 2011
    412
    62
    Minnesota
    I'm sure it is now with the EFI. We also ran it on the Rich side and kept the timming safe. I ran 110 at the track and more timing and spark.
    • Like Like x 1
  10. Kwik_Cutty88
    Kwik_Cutty88 Moderator
    Nov 22, 2011
    1,034
    234
    Coastal North Carolina
    Congrats! Those are some nice numbers. That should be a really really stout street engine. I'd love to see the dyno graph.
    • Agree Agree x 2
Loading...
Similar Threads - Dyno run 383 Forum Date
My Delta 88 (before a hit and run) Photos, Videos, etc. Jan 7, 2018
1988 Super Sport @gbodyrun2017 Photos, Videos, etc. Oct 3, 2017
G Bodies at the Pumpkin Run Photos, Videos, etc. Nov 6, 2016
My 87 Salon with the 330 actually running after 10 years... Photos, Videos, etc. May 23, 2016
Decided to actually run halfway decent. Photos, Videos, etc. May 17, 2016
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
