Hello all...
I'm experiencing some disappointment after my first dyno run...
I don't think I'm generating the power I'm supposed to...
I mean, I can turn the wheels fine and I get good power, but not as much as I expected...
On the dyno run I got 240 max hp and 260 max torque after I had the timing properly set...
Here are my components for anyone interested in helping me solve my enigma...
Cam: http://store.summitracing.com/partdetail.asp?part=EDL-7102&autoview=sku
Intake: http://store.summitracing.com/partdetail.asp?part=EDL-7516&autoview=sku
Cylinder Heads: Vortec 062s
I've been told that my cam and heads don't match, but the machinist had the specs on my cam and machined my heads to accommodate it...
Keep in mind that these aren't my original specs. I had some double hump heads, but the machinist shaved them too much and I ended up with water in my oil pan... :evil:
The mechanic that was with me running the dyno thinks my carb (670 Holley Street Avenger) is too small and he thinks I would benefit greatly from an upgrade to the ignition system...
Any input is welcome...
