Fixing my rusty floor
Down Shift
12
13
The passenger side floor in my 79 Malibu is toast. It is super thin in the front and has already been patched once. The rear pan is worse. It's also rusted out around the seat bracket and the center support. Pics below for reference...
I bought a complete right floor pan. I have a decent MIG welder and I know how to weld sheet metal well enough. I need to pull the right side seat support and the center support. How do you guys go about that? Just drill out the spot welds and prop it up out of the way while you cut and weld in the new pan? Also, I am going to put bucket seats in the car. Will the replacement brackets on Ebay work with aftermarket brackets, or do I need something else?
Thanks!
Clone TIE Pilot
3,831
2,566
Galaxy far far away
Harbor Freight sells spotweld cutters. I would also check for rain leaks too.
HADA442
26
7
Ironically: I just went through repairing the same issue on mine, although I guess (?) I lucked-out and the rear wasn't as bad. A buddy of mine ended-up welding-in a Goodmark pan and it fit pretty well!
wonderboy24
1,322
1,299
Davenport, Iowa
i had to replace the back drivers side floor the rest of the floor was good. i laid the patch panel in. cut it out to the exact size. not over lapped and welded it in..
wonderboy24
1,322
1,299
Davenport, Iowa
i dont know to be honest.i bought the car off a buddy. and pulled the carpet out to replace the interior and found it. i only owned the car for 2 weeks and it sat in my garage till i pulled the interior out.
Clutch
5,183
10,900
Brick NJ
Yes carefully drill the welds and remove the brackets I use a pice of sand paper to lightly clean the welds to find there exact center before drilling use a bit 8 mm or 5/16 get center and they should let go without a chisel sometimes after drilling they can be poped with a sharp puddy knife. Think it threw and you have a floor in no time
