Floor shift stearing column
Toadstool
20
58
13
Lockeford CA
I've got a 78 cutlass non tilt column shift steering column. I just installed floor shifter. what years floor shift steering columns will work for the 78.
I was hoping the wiring harness would match up from the later year cars.
Or is should I just cut off the column shift lever nub.
Thank you for your help.
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,174
9,776
Gainesville, Fl
...a '78? Unless of course you replace the column with a'79 and later column and replace the intermediate steering shaft as well.
...or like you said, remove the handle, grind the nub down and fill it.
Tony1968
2,323
5,126
NW Indiana
That shifter setup looks great.... What BM unit is it and did you modify to get it to look like this ?
Toadstool
20
58
13
Lockeford CA
I bought a b&m quicksilver shifter new in the box at a swapmeet. I just painted the small console the interior color(still trying to match the console to the interior color a little closer)it was so very easy to install. I added the hurst shift handle and hurst olds emblem because I made my 78 olds a hurst tribute car.
I hope that info helps dude good luck with your project.
L.A.X-RATED
1,387
385
83
Great solid cond Hurst bucket seats in camel,with factory console that I can adapt the quicksilver to(as I have 5 of them on shelf)---875.47 shipped.pm me if interested.is a "tribute" car the same as a "clone" car? Always wondered this? Looks like you are headed in the right direction with your approach none the less;)
