So on my 1995 F150, I have replaced nearly the entire braking system, including all of the emergency brake cables. Now for some reason, with all new parts (I'm certain I've got the correct parts), the rear drums are giving me issues. Just for reference, I have replaced the shoes, all the hardware, adjusters, springs and both wheel cylinders and the emergency brake cables front to rear.
Now the driver's side rear brake seems to be working just fine. I have plenty of adjustment in it and I can easily get the drum on and off.
The passenger side is where I'm having an issue. The rearward shoe will not seat into place because the emergency brake cable is too short once inside the drum and its pulling the parking brake lever too far forward and the parking brake lever hits on the axle tube itself before the shoe will seat.
Because of this, the drum needs hammered over the shoes with the star adjuster all the way in and then is still way too tight and the wheel won't turn. And because it is so tight, the emergency brake pedal is way too stiff to push down.
It's almost as if that right rear cable is too short, but it went into place easily and is the exact same size as the one I took off.
I'm wondering if u have the left and right cables flipped around in the equalizer bracket which may be using up a little bit of slack, but I can't find a diagram or other truck around to check. I installed it the same way it was before, so it would have had to have been wrong before as well.
At this point I'm sore, cold,and frustrated with these brakes. I've had them apart about 15 times now and they still are wrong. I'm about ready to throw in the towel and take it to a mechanic, which I really don't want to do. I'm asking here as a last resort. Any ideas?
