So I've been driving my Dad's truck while he's away on vacation; '05 F-150, 5.4L triton etc etc, and lately its been running funny. You get on the gas and around 3-4000 rpm the motor hesitates and kind of stutters. Then after doing this a couple times the check engine light comes on. I got the code read and it was a cylinder misfire on #4. I decided maybe plugs should be done, they're long overdue (he's not too great with maintenance), and i attempt to take one of the plugs out.
First off, the plugs are a 9/16" socket! Then, i do some research and almost everyone who has attempted to do plugs on the 3V triton motor results in the plug breaking into 2 pieces, requiring that the porcelain piece be broken off, and a special extractor is then needed to retrieve the rest of the plug!
Special Extractor: http://www.denlorstools.com/home/dt1/pa ... 0_alt.html
Oh, and the "special" plugs for this motor are worth 14-15 dollars each!
ALSO, through research i learned that there are a ton of cases where the 4.6 and 5.4 motors had a spark plug BLOW OUT of the cylinder head and the threads were totally shittered. How does Ford get away with this?
As you can probably guess, i've decided to not even touch the plugs anymore at the moment in fear of screwing it all up. Other than this I really enjoy driving this truck, but I think i'll stay away from buying any ford with this motor. Ever.
Joseph
Joseph
