Yeah I doubt that’ll happen. I had to drive 3 hour there and back for the motor he was asking 550, for it ended up getting it for 540Get your money back if you can.
Or
Strip it completely down and have it hot tanked and see what the machinist says about the piston and lifter bores.
Well I actually have stock rods out of a 350. I called a machine shop that said they could got tank it for me for 50$ not too bad I guess.Looks like OE style dished pistons so there might be enough meat @ the cylinder wall to bore it out for possible use. If they are stock pistons, it likely still has stock 5.565" (short OE 400) rods. The rods would work for a budget build but most prefer 5.7 (350ci) rods instead. Each possibility requires different pistons. You don't know until it makes it to a machine shop.
If you're avoiding machine shops, what you purchased might be viewed as an expensive lesson which sucks. Where are you on the map??
Getting a quote to hot tank, check for issues/cracks, & measure the bore is a good start.Well I actually have stock rods out of a 350. I called a machine shop that said they could got tank it for me for 50$ not too bad I guess.
I hate to say it but I think your right. Huy told me he was able to crank it over by hand using a bar. I can’t get it to turn for sh*t.It’s a core. Begin a full rebuild that engine isn’t running again. And if it does it’ll be a smoker.
I checked the in between the steam holes where they usually crack. No cracks so the block has tj at going for it ahahaGetting a quote to hot tank, check for issues/cracks, & measure the bore is a good start.
I’m in North west indianaLooks like OE style dished pistons so there might be enough meat @ the cylinder wall to bore it out for possible use. If they are stock pistons, it likely still has stock 5.565" (short OE 400) rods. The rods would work for a budget build but most prefer 5.7 (350ci) rods instead. Each possibility requires different pistons. You don't know until it makes it to a machine shop.
I'd definitely pay for a magnaflux with the hot tank to check those areas too. Never know if there small stuff compromising integrity you eye doesn't pick upI checked the in between the steam holes where they usually crack. No cracks so the block has tj at going for it ahaha
