Found the correct thermostat housing and hose combo for my setup
Tynan918
1,136
249
15° thermostat housing and this hose from the scrap yard
  • Useful
g0thiac
939
582
Tynan918
1,136
249
So when is the first drive here lmao? You said an oil change and a few other things? As I think we covered everything else, or at least I thought we have lmao 🤣🤣🤣🤣
I've only taken it around the block a few times...😎🤣🤣🤣
Checked all fluid levels, all good but still doing the oil change.
I think either my throttle cable and/or kickdown cable is misadjusted... shifts late and slow take off...
Haven't touched my idle mixture screws and I'm not sure I'm using this manual choke correctly lol
SSMonteMan
111
225
I can't seem to put my finger on it... But it sounds like you've got an exhaust leak or something off... That ticking noise is not normal. Also, the vacuum gauge popping back and forth like that isn't normal either, at least mine doesn't do that. It's pretty solid. Might be a sticking or leaking intake valve, or a rocker arm out of adjustment.
g0thiac
939
582
Glad to see this. Enjoy and next time, keep a bit more of an open mind when interacting with people here man.
Nobody wastes time posting here to get their car OFF the road haha. Time to enjoy the warm weather and see if the work you have performed becomes up to task or not haha.
Tynan918
1,136
249
More than likely misadjusted rocker valve...passenger side...cylinder 2 or 4...
