CUTLASS found the date code,i think.
oldolds
239
76
pine city/rosaila washington
on my 1980 olds cutlass calais i found the date code on the front of the engine behind the water pump between the oil fill tube and the sending unit i think. it says 4790 gm is this right and where is the casting no. is it to the left of the oil fill tube behind the ac compressor or behind the alternator? or is it in the back by the dist? i am confused. it is not the original engine just not sure what year. not enough thermo vacumume switches. i thought about bypassing all the vacumme lines and simplifying but i don't think i can out think the gm engineers, the things were there for a reason.
Oct 14, 2008
8,819
7,766
Melville,Saskatchewan
What do the big cast in numbers say behind the water pump on the shelf by the oil sender and oil fill tube?
Oct 14, 2008
8,819
7,766
Clean the area, that doesn't sound right.
Oct 14, 2008
8,819
7,766
What number is in front of the #1 spark plug?
