I need to clean up a bit after selling the rotte carlo ss. I've got some things new coming and the space is lacking. With one project gone some extra stuff both from it and intended for it
In the free pile before i scrap it:
1 broken black SS spoiler. If you want to spent the time to build up the broken areas of fin, have at it. Trunk mounting surface intact, looks like chunks broke from people pulling trunk down by spoiler edge.
1 heavily cracked grey monte dash. Try your recovering skills. No trim/gauge pod/climate/etc.
1 trunk floor. Rusted by the #5 body mounts. Other areas where bushing sat and z-nut cages were are rusted out. The flat part of floor above gas tank is OK.
1 gas tank. Non-efi. Untested for pressure/leaks. Was in trunk of car when I got it so I put a used low mile tank I had in to get it going quick.
In the relatively cheap pile:
Set of (4) 14" Olds super stocks. Painted black. No tires. $150
Set of (4) 15" Camaro z28 wheels. Have old tires on them. Were on the rotte carlo but guy brought his own wheels when he bought it. $225
G-body frame. This is the one I drove into SC to pick up for the cost of gas and labor to remove what the guy wanted to keep. Was worse than represenred. Needs mount holes repaired, likely easier to swap rear rails as well as they got thin. Good front control arms/spindles/brakes/steering linkage. Has some bits of floor remaining, I may cut them off if time allows in case I need to chop the rails to scrap. Give me $125 to cover the fuel. Good control arms ought to be worth that much. If you prefer it can get cut behind the crossmember and you just take the front subframe for the parts, doesn't matter to me.
Can't ship it, but pick-up available in Coastal GA near the SC line off I95.
