Front backing plates new
565bbchevy
565bbchevy
7,234
Michigan
This is my first time seeing these new, I know I looked a few years ago when I was redoing my Regal and couldn't find exact replacements back then.
Looks like they are available from ThePartsPlace directly or a vendor like below.
liquidh8
liquidh8
I remember on more than one occasion these being searched for.
69hurstolds
69hurstolds
3,638
From what I've HEARD about the repros- based on other people's feedback:
They fit ok, but they're a little thinner metal than originals, and the finish like on them is more like a thinner zinc plating instead of OEM galvanized (typically 10 times thinner zinc coating than galvanizing). Which I would imagine may show signs of rust up to 10 times earlier depending on use/environment.
I haven't heard a lot of grumbling about this particular repro part. So maybe that's a good thing. Between these and nothing, I imagine these will do. I've never used them or had my hands on them personally. Maybe someone with real world experience can chime in.
69hurstolds
69hurstolds
3,638
Mike's Montes sells them too. Same price $89.99 per set. GM ones are unobtanium now. They discontinued one side, then the price went to like 80 bucks each for that one side that was still available, and now the OEM's are gone. IIRC, you could buy them for around 40-50 per pair from GM at the time.
565bbchevy
565bbchevy
7,234
Michigan
A few years ago when I was looking for new shields for my Regal I ended up buying ones that would fit but came with an ABS sensors and these were from Dorman 970-098 and 970-097 and I then ground the sensor off to make them work and made gaskets for the backside, luckily these were only $50 for the pair to my door.
Reactions: melloelky
