i liked 1 of your old posts that couldn't reply too. "One of the biggest problems for most folks, INCLUDING S-10 owners, is that they have no freaking idea where to get the front LCA M14 bolts for the front position. They don't know the size or anything.
So....I'll never swear to knowing for sure, but a little parts book told me....
M14x2.0x110, GM p/n 11509777. Are these the same exact length as the front LCA bolts on a G-body? YES. The front LCA bolt on the FRONT side for G-body is GM p/n 11500952. Discontinued from GM. M12x1.75x110.
Problem I'm seeing with the G-body parts book however, is I see the bolts are listed "backwards" in the illustration manual. The front position front LCA bolt says it's 95mm long, but it's wider than the rear so I don't see how or why they would do that. It only makes sense to believe that they accidently swapped them. 110 mm in front, 95 mm in the rear. Parts book shows them azz-backwards.
Since the GM front LCA front bolt for a G-body is discontinued, if you need a new M12 bolt for the front side of your front LCA, you can get a Mopar part #6502809. It's the same exact size per specs, however I've never actually laid eyes on one.
For reference, the top bolts to hold the front UCA to the frame are GM p/n 461854, same as a G-body. M12x1.75x66
The front LCA bolt on the rear side is the same as the rear control arm bolts for a G-body, p/n 11502603. M12x1.75x95
M12x1.75 nut is GM p/n 11516073 which fits rear Upper Control Arm bolts on a G-bod as well."
you seem to have the best info on this stuff, i assumed all 4 were same size and what not. you're saying the rear bolt is same as the 1s used in the rear control arms? and am i right to assume all 8 RCA bolts are the same, which i already found with the nuts are there any special washers i should be getting? now i found this http://oemcats.com/oem-parts/11500952.html which looks like is the "discontinued" bolt but not sure what nut i need for it or any associated washers.
