Front & Rear Bumper Trim - 78 Lemans
BronzeLemans78
BronzeLemans78
23
13
Anyone know where I could source replacement trim pictured? It's 1 3/4 in wide. Everything aftermarket that I've found is either 1 3/8 or 2 in, no one makes 1 3/4!!
This is plastic, and as you can see it's pulling away from the contours of the front bumper. I've removed the rear already figuring that it would be easy to source, but got surprised.
Should I not be able to source something, any ideas on alternatives to the trim? There's a channel that needs to be filled. I'd rather not put body filler in the car, but for the nose piece and rear bumper I might consider.
TIA for the feedback.
P
PBGBodyFan
400
Wisconsin
I believe gbodyparts.com recently came out with a strip for the LeMans bumpers but can't find anything on their site, might be worth a call. Not sure how good of a match it was, I'd guess close but not perfect like most of the aftermarket trim seems to be. Some seems to be things found that match "close enough" but aren't really made for that purpose by 3M or the like.
79 USA 1
79 USA 1
606
Cheektowaga, New York
Have you checked Auto Zone or Advance auto stores for Chevy or GMC truck side door trim.
I know quite a few 78-80 Monte Carlo owners are using that style trim due to the mylar bumper strips being like hens teeth to locate.
Don57
Don57
Apr 12, 2009
67
St. John's, NL
The original factory moulding is pretty much impossible to find. The very best you can come up with is a body moulding that was used on Chevy/GMC trucks in the 70's and 80's. I have bought it and used it on my Grand Am and it matches the factory moulding. You can by it by the foot or by the roll. Check out ebay items #301989280511 or #152588337755. If I knew how...…..I'd attach the link. Here is a picture of my GA with this moulding on it. Good Luck!
Thread starter Similar threads Forum Replies Date
houston_t Rear to front brake line. Wheels / Tires / Brakes 1
CDUNIGAN1981 Kore3 C5 Front and Rear question Wheels / Tires / Brakes 16
C MALIBU Anyone running 17 in the front and 15 in the rear ? Wheels / Tires / Brakes 5
Hippi 78-81 lemans inner front fenders G-Body Parts For Sale / Trade 7
Rus Front shoulder belt removal Interior 3
S In desparate need of a passenger front wheel well moulding/trim w/2 tone paint for my 85 ElCo Wanted 3
R 1999-2003 front steering knuckles Wanted 11
Olds G's 1984 G47 Front Fender Lower Trim Oldsmobile Cutlass / 442 / Hurst/Olds 4
nickonometry Cutlass front spoiler options Oldsmobile Cutlass / 442 / Hurst/Olds 1
350Cutty **Moving Sale - Cutlass Front End $50. G-Body Parts For Sale / Trade 9
Tyler l Front clip change General Discussion 1
Kelvin's80442 Front suspension,crossmember,hood 80 442 Wanted 8
7 NOS LeMans Front Bumper Cover/Header Panel G-Body Parts For Sale / Trade 0
M Front air dam Wanted 3
airboatgreg Front Shocks General Discussion 9
H Questions on parts for 87 442 front turn signal gasket and wiring cover Oldsmobile Cutlass / 442 / Hurst/Olds 2
J Aftermarket hurst front spoiler General Discussion 1
P 1980 Cutlass Supreme Front Bumper G-Body Parts For Sale / Trade 0
S Looking for passenger side front wheel well molding w/2 tone paint for my 85 El Camino Body / Trim / Paint / Glass 0
P 1981 LeMans front end G-Body Parts For Sale / Trade 2
M 84 cutlass.Need front license plate holder Body / Trim / Paint / Glass 0
K CUTLASS Front bumper badge Body / Trim / Paint / Glass 2
gnvair 15" Front tire sizes that will not rub Chevrolet Monte Carlo / SS / Malibu 15
K NIB Spohn Front upper Tubular Control Arms 1978-1987 GM G-Body G-Body Parts For Sale / Trade 8
I Front Springs Frame / Chassis / Suspension / Steering 1
565bbchevy Front backing plates new General Discussion 5
Tim & sleek Front brackets General Discussion 7
Cajun83HO LS front crank seal replacement General Discussion 7
J front end parts? Frame / Chassis / Suspension / Steering 5
J Front license plat bracket? Oldsmobile Cutlass / 442 / Hurst/Olds 28
Wageslave Best front end changes for high speed stability? Frame / Chassis / Suspension / Steering 20
V Front suspension race car Frame / Chassis / Suspension / Steering 5
R ?? Front body mount replacement Body / Trim / Paint / Glass 0
O Wanted 1981 Olds Cutlass front license plate holder Oldsmobile Cutlass / 442 / Hurst/Olds 0
abstracts18 G Body Front air dam/splitter help Oldsmobile Cutlass / 442 / Hurst/Olds 3
gnvair Can anyone definitively say that the front lower control arms from an S10 will work on a 78-88 A/G body?; Frame / Chassis / Suspension / Steering 22
B Adding front spoiler/splitter to Monte SS nose General Discussion 2
Mikko F-Body Hollow front sway bar install help Frame / Chassis / Suspension / Steering 7
Macguyver Autocross ready front end kit! Autocross 1
I Front end replacement parts Frame / Chassis / Suspension / Steering 2
H Need 87 442 front bumper cover decal and stripe Oldsmobile Cutlass / 442 / Hurst/Olds 5
D Front sway bar problem Frame / Chassis / Suspension / Steering 8
D Front spring install suggestions Frame / Chassis / Suspension / Steering 28
G Finding Front-Axle Center line Frame / Chassis / Suspension / Steering 15
H CUTLASS Front sway bar bushing bolt mount stripped Frame / Chassis / Suspension / Steering 34
L MALIBU Front suspension hardware Frame / Chassis / Suspension / Steering 2
mickeypowa lowered front and 235 60 tires Frame / Chassis / Suspension / Steering 12
D Front suspension???? Frame / Chassis / Suspension / Steering 35
Bullett801 3rd gen front rotors General Discussion 8
Tomeal Front UCA's Frame / Chassis / Suspension / Steering 11
Similar threads
