OK SO Im finishing up the hubs for the c5/c6 swap on the 80 malibu. the studs are too short looking into a longer ones
what studs have you guys used and has anyone done threaded front studs? ill post and example below
in the numbers part of this game the front knurl spec is .564?
the stud i pulled the knurl measured @ .548 at the largest number
trying to move up from 7/16 to 1/2 or 12mm on the front the rear is easier to match both of the newer/ bigger sizes
once i get the front fingered out ill buy rear axles and studs ..
anyone tapped the front hubs before?
should i stick with press style?
looking for 2-2.5" thread length to rid any issues with wheels and or addition of spacers/ adaptors
