Front sway bar bushing bolt mount stripped
hoffa65
319
416
Atlanta GA
Has anybody had to repair stripped threads in the frame for the sway bar bushings mount?
Is there enough room to go up one in bolt size?
GuysMonteSS
1,449
1,541
Kentville,Nova Scotia,Canada
One option if you have access to a welder is to drill the hole big enough to put the proper size nut in,after rounding it off,and welding it in place.
Guy
gnvair
1,098
1,296
The right side has a large hole where you can put a nut inside. The left side is a b*st*rd as it has no access holes. You need to weld it up and redrill and tap. I have also seen people still the holes over size and make a plate with 2 nuts that fits into the holes.
I have the stripped hole problem with one of my cars that I still have to fix
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
what about using green loctite to install a stud
Longroof79
Rocket Powered Basset Hound
G-Body of the Month
Oct 14, 2008
12,156
9,762
Gainesville, Fl
You could also consider a nutsert. However, the type I tried to use needs a special crimp tool to lock it into place. One side I welded up, the other side I used a few nuts temporarily accessed thru the hole on the passenger side.
Another suggestion that I think 565 used was using U-bolts.. ..if I recall.
I do like the idea of using a plate with nuts welded to it. There's several variations, It's up to your preference of how you want to a achieve it.
hoffa65
319
416
Atlanta GA
Looking at a Keensert with red loctite on the outter threads, have them at work but i have to find a 14mmx1.5 tap we only have a 14mmx2 and a 14mmx1.25. Figures lol
Longroof79
G-Body of the Month
Oct 14, 2008
12,156
9,762
Gainesville, Fl
A 14 x 1.50 tap should be a pretty common size.
Sorry, I was actually thinking M8 x 1.5.... M14 is rather large, isn't it?
