With all things being equal (same bushings, end links and solid construction) would a 1.25" factory F41 front sway bar have any disadvantage compared to an equal size aftermarket front sway bar?
I was comparing solid to solid.Weight may be the only factor. Depends if the aftermarket bar is hollow or solid like the factory bar. Hollow bars are more susceptible to break, but if it's a well made bar, you probably won't.
USUALLY hollow bars are just slightly less stiff than the equivalent sized sold bar, but not by much. Not enough to notice on a G-body with a big block anyway.
