FS: Olds 260 from 1980 Customer cruiser
Trader history for Nutty Cutty (0)
N
Nutty Cutty
Apr 30, 2019
53
I pulled the running 260 ci V8 from my Cutlass custom cruiser project and it's been riding around in my truck for way too long. It ran the day I pulled it but I never drove the car.
The mileage is rolled over and says like 40-50K so...who knows...240K? a really nasty 140K?? lol IDK
It all all stock and complete from Carb to oil pan, flywheel, converter, dizzy and front accessories.
I pulled it myself so I did cut the crossover exhaust pipe that goes under the oil pan and the Dist sustained some slight damage but should still work fine.
What are these worth?
LOCATED IN SOUTH GEORGIA
TURNA
TURNA
8,160
Socialist NY
I'm new to the Olds thing but I thought only the 403 and 307 used the 5 bolt hole valve covers?
N
Nutty Cutty
Apr 30, 2019
53
I may be wrong honestly. I'm not exactly sure. Here's what I could find on it.
Sent from my SM-G965U using Tapatalk
TURNA
TURNA
8,160
Socialist NY
Right next to the oil fill tube is the block number above and behind the water pump.
or there should be a number on the cylinder head
See the A in the left hand lower corner what number or number and letter is there
JAMCAR223
JAMCAR223
679
Houston, TX.
Worth $150. Someone might give you that much to use the "accessories" on another build ( 350 / 403 ) - Distributor, oil filter adapter, oil fill tube, dip stick, thermostat housing, front brackets, oil pan, and engine bolts.
Reactions: DRIVEN
DRIVEN
DRIVEN
5,855
Owyhee County
Agreed. The parts are probably worth more than the engine. I could use most of what JAMCAR223 listed but shipping would be a killer.
GLWS. It'll find a home.
Reactions: JAMCAR223
