Fuel Gauge
Dylan88
160
22
Hello I have a 81 malibu with a 5.3 swap. The fuel gauge doesnt work always reads way past full buried and never moves. Guy said it might be sending unit or ground anything i should look at first?
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
Sounds like the sender wire is grounded. It comes out of the driver's side taillight harness; make sure it isn't pinched. Or, unplug the connector in the trunk, and see if it drops to empty.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
The sender wire is the pink one. The fuel gauge is just a ohm reader so it's easy check to see what the problem is.
timo22
550
1,072
St. Louis,Mo
Sounded like the sender wire is grounded. It comes out of the driver's side taillight harness; make sure it isn't pinched. Or, unplug the connector in the trunk, and see if it drops to empty.
Correct me if I am wrong but I think it is just the opposite. I thought a full ground would make the gauge read empty and an open circuit would read past full.
Tim
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
Hence, the vague "sounds like" in my response. ;) Honestly, I can't remember! You bring up a good point because the OP mentions an LS swap which would require a GN or TBI Monte sending unit, and it may not be hooked up at all.
Found this handy little chart:
  • Informative
Dylan88
160
22
Do you have to drop the tank to get at the sending unit? Or what should I test first?
