I'm trying to find out the specs on the sock filter on the fuel pick up. It's recommended that I run a pre filter which should be 20- to 40-microns. I just had one pump fail prematurely so I am trying to cover all bases. I had the pick up out of the tank recently and the sock was in good shape with no garbage stuck to it so I thought I was good to go. I did read that there are fake Walbro pumps out there from China that you can buy for $50 so I might have had one of them. The pump I got with the kit is the same that comes with the Fast kit but may have been purchased on it's own, I'll find out once my friend gets home from vacation who I bought the kit from.
Would you guys run a pre filter or is the sock sufficient. I'm thinking the sock will do the job but I have been wrong in the past.....once....
