fuel pressure gauge
scarborough
307
66
installed fuel pressure gauge on a edelbrock carb the needle flutters like crazy when it's at idle and when you give it the gas.any ideal what would cause that happen or is that normal , its a Mr. gasket brand that attach on the fuel line made for drop filter air cleaner. it has a stock fuel pump and mild cam. its not liquid fill, not sure if that matters.
spicercars
142
114
Saginaw MN
I had that problem some years back and had to bleed the air out of the line then it seemed fine. Don't know why that should matter.
Ribbedroof
4,900
6,992
Wellston, OK
Because air compresses with the pumping action, liquid does not
melloelky
4,161
9,568
mass
i had that same problem last year,it would fluctuate rapidly.after reassembling the car this winter its smooth.no idea.
