Alright. So heres what I can say for sure.
1. A big issue was the alternator wasn’t charging the battery properly, so that probably didn’t help with stalling.
2. The fuel filter in the carb should have been more cleaner, so I installed a new one today.
3. All vacuum lines, I have replaced and changed to suit my custom setup.
4. To avoid vapor lock, all my fuel hoses I have covered with foil.
5. I upgraded the pump this week to this.
The ACDelco one I will grab this month, as Holley isn’t the worst for pumps but I always like to get quality whenever honestly I can.
Mr. Gasket 12S Mr. Gasket Micro Electric Fuel Pump
Gravity fed type pump with simple two-wire design. Works on 12 Volt negative ground systems only. Includes fittings and mounting hardware along with easy to follow DIY instructions. Pumps require approximately one amp average draw at maximum delivery. Flows 35 GPH (gallons per hours at 4-7 PSI...
www.holley.com
