On an EFI engine, what would keep it from holding fuel pressure?
I'm having an issue with mine lately on the 455. Been trying to get it fired back up since I had it running last fall and its been pretty rough going.
I think one of my problems is fuel pressure. When I turn the key, I hear the fuel pump turn on and run for 2 seconds like its suppose to. However when I go to the passenger side of the car to check the fuel pressure, I can see it dropping really fast back to zero.
I checked for leaks and tightened all my fittings and everything seems good. In fact, last fall I had a few leaks in the system but it would never lose pressure as quickly as it is now. Would take it at least 10-20 minutes for it to drop back to zero.
Fuel pump is obviously working as I can hear it and have confirmed I have fuel pressure at the rails. So what's left? Fuel pressure regulator? It's brand new and was working fine last fall. What would cause it to fail all of a sudden?
Thanks for the help,
