ok so i just got my 350 with carb running in my 85 monte and it starts and runs great for a sec then it looses fuel pressure and dies and im usein the stock fuel pump from the 4.3 tank y is this happing?
454muscle said:You mean stock 4.3 TBI tank? Isn't that for the EFI engine? It pushes like 45psi and if you have a carbed engine you would have to use a good regulator to bring the fuel pressure WAY down.
jrm81bu said:454muscle said:You mean stock 4.3 TBI tank? Isn't that for the EFI engine? It pushes like 45psi and if you have a carbed engine you would have to use a good regulator to bring the fuel pressure WAY down.
It should only be pushing about 14-15psi, it's only tbi not tpi, lol. But ya you will need to be running a pressure regulator and it should be a return style.
86montedude said:ok so i just got my 350 with carb running in my 85 monte and it starts and runs great for a sec then it looses fuel pressure and dies and im usein the stock fuel pump from the 4.3 tank y is this happing?
