Is it essential that I re install a vapor return line from fuel tank to front canister? Can I just cap that line at tank and use a vented fuel cap?
Where did you get that? Does it come in a coil similar to the copper I've seen?I replaced my line to the tank using aluminum tubing. It's not expensive and easy to work with
Yes, I was doing some reading about the potential smell and I think it best to keep it contained, although I'm not really into running a hard line front to back now that the body is back on....Another thing to consider is the fact that fuel vapors smell really bad. If the vapor canister is in working order, the vapors will be consumed in the combustion process and you won't have to deal with smelling them all of the time. Just my .02.
