Hello all i looking for a Fuse Box that goes on the driver side interior under the dash if any might have one or know where to get one please inform thanks in advance
Don't forget about the change from type 56 & 59 terminals to metri pack terminals at the bulkhead conection around '83/'84.I've got a couple that I pulled from the wrecking yard. Thing is, the wiring doesn't just plug into the blocks. They are a two piece, each with their portion of the wiring harness factory assembled. What year is the vehicle that you need one for? How much electrical are you willing to cut/splice or disassemble,/reassemble? Depending on whether you are restoring a car from the ground up, or are trying to repair a driver, might help you decide if it is easier to locate/install a secondary fuse center.
i have a 79 El Camino the fuse block was damaged after Hurricane Katrina and is now giving me problems so i want to replace it with a stock replacementI've got a couple that I pulled from the wrecking yard. Thing is, the wiring doesn't just plug into the blocks. They are a two piece, each with their portion of the wiring harness factory assembled. What year is the vehicle that you need one for? How much electrical are you willing to cut/splice or disassemble,/reassemble? Depending on whether you are restoring a car from the ground up, or are trying to repair a driver, might help you decide if it is easier to locate/install a secondary fuse center.
