87 Monte LS...the 20 Amp fuse in the c/h port is good, but won't activate my test light. I pulled the fuse out, and tested the port itself, with same result. Can not find a wiring schematic to trace the problem. Help please
The c/h circuit is the choke heater. My oil/choke light is on. Oil level is good. I'm new to mechanics and electrical work, so not sure what fusible link you are speaking ofIf the fuse is "good", at least one side will light the test light. I don't know what the "c/h" circuit does, but if you have multiple constant powered circuits in-op, you may want to check the fusible links at the starter.
That's probably an ignition circuit. Did you have te key on while testing? Does your test light work?
