Future 6.0/6l80E swap parts = $$$$
Injectedcutty
Injectedcutty
3,179
7,506
Louisville, KY
#41
I've been researching DBW (what my donor vehicle has) and I'm not sure I want to keep DBW. What mods will I need to do to convert to DBC? I know I'll need to change the throttle body but unclear what else. Which "gas peddle solution" is easier? Suggestions? What does the $400 Nick Williams TB better than the $150 Holley Sniper?
Your factory gas pedal will work fine for DBC. Just get a $100-150 92mm throttle body. The Nick Williams unit is nice, but plenty of guys are making a shit ton of power on the stock TB, or an ebay TB.
Northernregal
Northernregal
584
1,647
Red Deer AB
#42
You need a compatible ECU, has to come from a donor with DBC. There is a chipset difference on the board itself.
Not much benefit to a really expensive throttle body. Maybe a few small features and benefits. Warr Performance or Snake Eater Performance sell good cheap units.
FastCraig
FastCraig
Sep 11, 2017
92
60
Huntington, WV
#43
FITECH 92MM has IAC motor, TPS, gaskets included and is only $159. The only drawback, if it is one, is it is cast instead of billet. The others I looked at are more expensive and don't even include gaskets (add $25).
1546363123492-png.102565
Turbolq4
Turbolq4
1,007
1,699
Nampa Idaho
#44
Some of the early(ish) ECMs have the ability to run both dbw and dbc, mine does (2001gmc Yukon). Associated wire harness modifications are also needed. The stock Gbody pedal assembly worked for me along with a throttle cable from a truck with a 4.8/5.3/6.0
Northernregal
Northernregal
584
1,647
Red Deer AB
#45
The 2004-2005 blazer 0411 ECM was also dual capable. Usually easy to find too
Texas82GP
Texas82GP
4,589
7,359
Spring, Texas
#46
Don't forget if you use a Gen III ECM with a Gen IV engine, you need to do something so the Gen III computer can read the Gen IV crank and cam. The Gen III reluctor wheel is 24 tooth where the Gen IV is 58 tooth. You have to pull the crank to change the reluctor wheel. Another option is the Lingenfelter converter box. That's what we did on my brother's 78 Z28. We used a 2010 L96 6.0 with a Gen III ECM and a DBC throttle body.
FastCraig
FastCraig
Sep 11, 2017
92
60
Huntington, WV
#47
Thanks for the input gentlemen. I think, just for the KISS principle, I will keep the DBW and change the pedal. I don't mind the lag on initial acceleration and it may be tuned to eliminate most of that. Even if the lag can't be totally eliminated it isn't a huge issue.
Turbolq4
Turbolq4
1,007
1,699
Nampa Idaho
#48
And you can have cruise control too!!
BobinHSV
BobinHSV
11
#49
I have followed this thread closely and I am doing a similar swap into my Gen 5 El Camno. L76(DOD Removed, LS3 Cam)6L80E trans. I have all of the mechanical and wiring issues addressed except for 1. Everyone says it takes "a lot of hacking on the tunnel to make a 6L80E fit". Can anyone quantify with numbers what needs to be done. I can cut out the complete tunnel and install the eng/trans , then go back to fit the tunnel top. I would prefer to have a new tunnel top in hand when I start the swap. I want it complete in 2 weeks from start. I already have the fuel system, rear end mods, driveshaft, Mount kit, oil pan and other pieces. The complete engine/Trans will be run and tested out of the car before installation.
FastCraig
FastCraig
Sep 11, 2017
92
60
Huntington, WV
#50
I have not seen any measurements for how much trans tunnel was cut out to accommodate a 6l80. Here is a link of different transmissions sizes. https://gbodyforum.com/threads/trans-dimentions.70834/ There is a guy on LStech who did this swap and he has a lot of info along with a few pics of the trans cutout. I don't remember him giving any measurments. This is the thread I was referring to, https://gbodyforum.com/threads/ls1-swap.64205/post-602872
Thread starter Similar threads Forum Replies Date
B G-Body LS Swap 20
Winkernod G-Body LS Swap 27
E G-Body LS Swap 12
Markt361 G-Body LS Swap 0
motorheadmike G-Body LS Swap 27
Similar threads
