Hey guys .... new to the forum. I dont know if I am posting in the right area so forgive me ...
Just picked up a 79 Camino back in Dec. I have a sloppy column shifter and decided to see whats up with it . When I removed the arm, I found that the spring is broken. Looking on you tube, I saw that the guy simply removed the spring with a magnet. I was able to remove the broken part of the spring, however.. the remaining portion of the spring is stuck in the column. I tried using a pick with no success. Has anyone had this issue before ? .. please help. I fear my car may roll out of park on a hill or worse. It was tilt column if that helps
