G Body DBW Pedal
SStavin
SStavin
Apr 3, 2015
52
103
Chicagoland
#1
So I picked up a Corvette pedal (ACDELCO P/N 25835421) for my swap. I'm trying to figure out the best way to mount the pedal as close to stock as possible. Did some searching but I can't really find many good examples of how others modified and mounted the DBW pedal. Anyone have any insight?
I did Start in on bending the arm using a vice and I must have put pressure on the wrong part of the assembly because POP! thing exploded into pieces. Lesson learned haha. Time to order a another.
G Body pedal on the left, new Corvette pedal on the right
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FGgeXrbr.jpg&hash=ba0f136e5e03a0b23653dab4ca739bc9
bending the arm on the new pedal to match gbody pedal
proxy.php?image=https%3A%2F%2Fi.imgur.com%2F39TrPpF.jpg&hash=6aeaab95d5c13a2a90c08434a88f9805
oops!
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FKmteguk.jpg&hash=49025fac4dd0660c683c47c8092c2360
fleming442
fleming442
4,167
3,987
Ok, I'm seriously confused. Why are you trying to match it? Can't you just move it to the left, and drill new holes in the firewall?
I'm curious because I am going to install a DBW pedal from a firebird in mine. I just haven't got there yet. See: Operation Lipstick on a Pig in the build section.
SStavin
SStavin
Apr 3, 2015
52
103
Chicagoland
#3
You'll see in the first pic that the two arms are shaped opposite each other. Without modification the Corvette pedal will hit the trans tunnel. Also, the alignment isn't quite right. I'd like the new pedal to sit as close to stock as possible. Keep in mind, this is after I bent the Corvette arm closer to the stock G Body arm. Here's a couple pics for reference....
Close-ish to stock mounting holes
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FrBeLA8o.jpg&hash=8b84c40eafc12535918ea4c92121bad5
Closer to stock G Body pedal location
proxy.php?image=https%3A%2F%2Fi.imgur.com%2F08HnyAh.jpg&hash=13befbd2a1a89c1f68375f9a6fa1930b
Injectedcutty
Injectedcutty
2,900
6,539
Louisville, KY
#4
I knew I've seen it done recently.
Check this video out....
SStavin
SStavin
Apr 3, 2015
52
103
Chicagoland
#6
80GABU
80GABU
n00b
Dec 28, 2015
2
#7
How did you end up solving this?
8
81cutlass
1,320
1,521
Western MN
#9
I seem to have read somewhere that a 07 or so Monte Carlo SS ls4 has a pedal that is much closer to fitting. Needs 2 wires repinned from what I recall.
I did similar to what the youtube video did. Used a pickup pedal, cut the arm off, cut the arm off the G body, welded the G body arm to the pickup pedal. Then drilled some new holes in the pedal bracket and bolted it through the factory G body 3 bolt plastic firewall mount. Yeah, have to have a welder for that one however.
fleming442
fleming442
4,167
3,987
I used a pipe fitting wedge, and split the layers of metal in the bracket. Then, made some wedge spacers to support it on the mounting bolts. This was an 02 F-body assembly...
Similar threads
