G-Body Disc Disc Proportioning Valve Question
Doug Chahoy
2,565
2,662
Yes it's 4 wheel discs . So my brake lines will hook up, correct? No other changes?
L92 OLDS
2,872
3,050
West Michigan
If the physical dimensions and mounting holes on your TA prop valve are the same as a G body you should be OK. As I mentioned earlier , the Cadillac Seville valve Is a direct replacement for the G body with no fabrication required.
michmalibuman
1,040
1,154
Having the same trouble bleeding the brakes on my QP nine inch with disc brakes and e-brake. Used a power bleeder an still no pedal. Do we have a good fix yet?:cautious:
el camino ss 84
377
223
Nw okc
I had the same issue with no pedal after swapping to Cadillac rear disc brake setup while bleeding the brakes. Had to bleed them 5 or 6 times before I got a hard pedal and brakes that work.
Post #10
I would also like to add that if you got QP's base disc kit, it is indeed the Seville/Eldo calipers. They are a mf'er to bleed. To aid this: cycle the e-brake a few times in between bleed sessions. The pistons ratchet out as you use the e-brake, thus reducing piston travel to the rotor.
michmalibuman
1,040
1,154
E-brake cables to long ? What are they doing to shorten them up? Got a U shape thing to take slack out of the cable and the first time I used the e-brake it broke.
