I'v been fighting this problem ever sense i installed a 9" last year, at least i'm sure that's when it started, It develops a shake starting around 40-45 MPH & never goes away, even at 85-90 MPH, Its extremely annoying & i'm to the point of stripping everything out & junking the body, its kicking my butt & the car is no fun....Ok, at times its worse then others, I thought i had it found & it was smoother when i loosened up the brakes, but a week later it was back just as bad, I have changed everything, & i mean everything including other tires/rims, It is definitely not a "vibration", the driveshaft has been checked twice & ruled out & the pinion angle was checked, it is a shake, doesn't matter if your under hard throttle or just cruising, It is tire speed related.
The 9" is all new from Quik Perf., it have a full spool, even had the 3rd. member re-checked for run-out & a another yoke installed, all there was good, it has adj. upper/lower bars. The only thing i haven't checked is to see if these drums are in balance, There new from quik perf., there 11.2", but what strikes me is it has 3 weights, All i have ever seem on them is 2, there the multi lug drums. As for the axles, there new also, they look straight & i checked run-out, I will say when its up on jack stands & i go through the gears you can feel the shaking but its not as bad as when your driving it. This is a 78 Cutlass Supreme.
Any ideas would be great.
