Gage cluster swap
Discussion in 'Electrical' started by vwed, May 18, 2017.
  1. vwed
    vwed Not-quite-so-new-guy
    May 11, 2009
    49
    29
    I have an 83 Malibu wagon with the round cluster with a speedo, idiot lights and a clock. I have a cluster with the speedo, gages, a tech with a small clock inside the tech. I'd like to swap to the gage cluster and have rad the procedure about the swap but I'm looking for anyone who has done the swap to explain any problems that may have come up during the swap. Thanks.
  2. Longroof79
    Longroof79 Geezer
    Oct 14, 2008
    8,882
    2,060
    Gainesville, Fl
    It should be a direct swap, being that you already have the round gauges. You will probably have to run a new white tach lead and tach filter. I don't recall if you need the printed circuit for tach and gauge cluster. I'm guessing that it's already included with your new replacement cluster.
    I would check the plug and make sure it's pinned and configured to accept the new cluster.
    http://www.maliburacing.com/gauge_conversion.html
    • Like Like x 1
    • Agree Agree x 1
  3. kalidromos13
    kalidromos13 Master Mechanic
    Silver
    Oct 12, 2016
    377
    287
    Palmdale, CA
    When i went from idiot lights to gauges i used the same webpage to reference the correct wires to the correct pin location in the connector. So Jack gave you some solid advice, just use that page as a reference.
    • Like Like x 1
  4. Longroof79
    Longroof79 Geezer
    Oct 14, 2008
    8,882
    2,060
    Gainesville, Fl
    Hey Dave,
    Thanks for your vote of confidence....:)
    • Like Like x 1
  5. kalidromos13
    Silver
    Oct 12, 2016
    377
    287
    Palmdale, CA
    No problem Jack, you have my vote any time!
    • Friendly Friendly x 1
  6. V8 Rumble
    V8 Rumble Royal Smart Person
    Jan 7, 2010
    1,292
    337
    83
    Connecticut
    As mentioned above run the tach wire and make sure you get the correct sender for gauges. I did the swap on my malibu from sweep to gauges using the link Jack gave above.
    You can click on the link in my signature. I made a video of my cluster swap.
    • Like Like x 2
  7. Longroof79
    Longroof79 Geezer
    Oct 14, 2008
    8,882
    2,060
    Gainesville, Fl
    Thanks for chiming in, Joe.
    I forgot all about the link to your informative video....and mentioning the correct senders for the gauges, etc..
    #7 Longroof79, May 19, 2017
  8. airboatgreg
    airboatgreg G-Body Guru
    Oct 2, 2016
    782
    492
    I also did this and your have to change the senders and run the tach wire to the printed circuit. I saw that a lot of guys did not run the filter from the tach. I did as the factory would not of put it there if it was not needed. Also you can make a cheap kill switch with a double pole switch branching off of that wire
  9. vwed
    May 11, 2009
    49
    29
    Thanks for all the info. The video was very helpful. I had read about adding the white tach wire but didn't think about finding a spare pin to slip into the connector. Would be great if it was as easy as adding a wire and changing out some senders. Again thanks for the help.
Loading...
Similar Threads - Gage cluster swap Forum Date
'86 Elky Oil Pressure gage Electrical Sep 22, 2012
Starter engages on own Electrical Jul 5, 2010
???s about hooking up gages Electrical Jan 16, 2010
Gauge cluster out NO accessories work? Electrical May 11, 2018
3g monte cluster diagram Electrical Feb 14, 2018
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
