Garage clean-up! OEM and aftermarket G-body parts!
Trader history for SStavin (0)
SStavin
Apr 3, 2015
85
33
Chicagoland
Cleaning out the garage and I have a good amount of leftover parts. All prices are without shipping costs. Pickup id preferred if possible. I'm in the NW Chicago suburbs.
- B&M Megaashifter - no housing - (PN: BMM-80690) – $200
- GM Serpentine brackets + everything you need for the conversion: Pulleys (including a/c delete), belt, powermaster 140A alternator (pwm-47861) OEM power steering pump, FlowKooler Hi Flow Mechanical Water Pump (PN: bra-1774) *** I do not have the hardware - $375
- Hotchkis upper tubular A-Arms (PN: HSS-1101) – $300
- Hotchkis Rear 1.5” drop springs (PN: HSS-1900r) - $100
- Modified B-Body spindles and hubs - $75
- K&N X-stream air filter assembly (PN:KNN-66-3010) -$75
- Rear seat frame brace kit (No hardware) - sold to Jamcar223
Similar: http://www.kirbanperformance.com/product/283/REAR+SEAT+FRAME+BRACE+KIT+#1586.html
SB CHEVY SHORT BALL MILL VALVE COVERS SBC - $45
OEM stuff (off my 1988 Monte Carlo SS w/ 80k)
- Burgundy hood - 6/10 does have a couple small dents and paint chips - $75
- Fan w/ new Clutch - $35
- Used Heater Core - FREE if picked up
- Computer - FREE if picked up
- Original suspension: upper and lower a-arms, front and rear springs - Gone
JAMCAR223
1,727
Houston, TX.
PM'd you @ seat braces.
JAMCAR223
1,727
Houston, TX.
What motor are tbe serpintine belts for Chevy or Olds?
This is the Chevy serpentine setup, that can be adapted to the Olds. You would need the adapter brackets that bolt to the block, a reverse rotation Olds water pump, and a Ford 302 crank pulley.
drb930
45
8
Los Angeles
What P/S pump is that ?
JAMCAR223
1,727
Houston, TX.
G-Body Performance Upgrades
