Gas pedal adjustment - for short people
Cuse99
251
126
Ok I'm short. 5'4". I can reach the pedal but I'd be more comfortable if the seat was a little back so I wasn't cramped on the wheel. Anyway I see that the pedal is almost sitting on the floor but I can lift it a good 4-5 inches, then it settles back. So I'm guessing there is an adjustment somewhere that I can get the pedal to stick out further. Is there a way adjust the gas pedal so it doesn't sit so close to the floor, but it still needs to be safe?
Thanks in advance.
81Regal
1,557
485
83
Terril Iowa
The gas pedal is bolted directly to the firewall. You might be able to attach a plastic spacer to the pedal otherwise there is very few options.
Cuse99
251
126
The base is attached but the linkage is attached to a bar/pole of some kind at the top of the pedal that goes through the firewall. If I lift the pedal that bar has some play to it, maybe 4 inches. Maybe I need to attach a photo. On the other hand there might be a nothing I can do.
Bonnewagon
Lost in the Labyrinth
10,564
14,298
Queens, NY
I am 5'5" and I moved the seat forward. I used a LeSabre power seat base so it just normally went farther forward than most manual seats. Then there is this.
  • Wow
GuysMonteSS
1,449
1,541
Kentville,Nova Scotia,Canada
Did you make that with your Meccano set ???
LOL
Guy
Cuse99
251
126
I can reach the pedals, but it puts me really close to the steering wheel and the sideview mirror is on my shoulder. In modern cars I can adjust the pedals back and forth, but also adjust the steering column up/down and in/out along with the seat to set up a really comfortable position. In my 84 the wheel tilts and the seat moves but that's it. I'd like to pull back from the wheel a little and it would be great if I could compensate by moving the pedals forward. I'll keep exploring this.
ck80
Moderator
Moderator
5,743
9,121
On a more serious note what you're encountering is a fundamental difference in technology and design of an older car/truck.
Modern cars are called "drive by wire"... you push a pedal, a sensor takes a reading, communicates through a computer and tells other parts to do stuff.
Older cars are cable driven. The geometry of the setup matters. On the old car you press the pedal, it tugs a linkage or cable, and that tugs some lever making something happen.
Point is, on a new car the relative position of pedals do not matter. All that matters is that the distance of travel gets measured and communicated.
On an older car angles, distance, and geometry of the levers and cables matter. It's not about measuring distance of pedal, it's about physically tugging things in the car to make it work.
Thats why adjustable pedals are more commonplace now, but a bigger undertaking in something older.
