GASKET SET OR "RIGHT STUFF"
Clone TIE Pilot
3,827
2,565
Galaxy far far away
Gasket set for what? One thing to keep in mind is that assemblies are often designed to require gaskets as spacers. Substitute sealant instead of a gasket can throw off the alignment of the parts.
Jakefromstatefarm
465
923
Buy the kit.
565bbchevy
9,590
12,612
Michigan
valve covers, oil pan, water pump, timing cover ,intake... not heads or exhaust or tbi
On my Chevy's I use Moroso reinforced rubber gaskets with no sealant for valve covers, Fel Pro 1 piece rubber oil pan gaskets with Permatex ultra black in the corners.
Name brand timing cover and water pump fiber gaskets with a light coat of Permatex Ultra black on both sides and for the intake I use printo seal style gaskets (AFR brand on the BBC) with only a bead of Permatex on the china walls
Clone TIE Pilot
3,827
2,565
Galaxy far far away
Don't get cheap gaskets either. For intake manifold gaskets I like to use the stamped shim metal type which resists being sucked in. Same reason to use shim core valve cover gaskets. Of course use 1 piece oil pan gasket.
