Gauge cluster
Scott78
33
19
8
Hi Everyone,
My 78 cutlass gauge cluster is having issues I replaced my oil pressure and temp gauges with new autometer gauges and put them in a pillar pod they work great but my voltage and gas gauges are acting up dont really know how much gas I have so I'm looking to replace the cluster.My question is has anyone built there own cluster if so how did you build yours and what materials did you use please post pics if avalible . Thanks
hoffa65
319
416
Atlanta GA
pull the cluster and clean the copper connections where the harness plugs in to the cluster. I have shimmed behind the circuit board with masking tape to tighten up the connection. be careful copper is very thin
Scott78
33
19
8
Hi Hoffa65
I've tried to get that cluster out before with no success I put a crack in my dash and don't want to do that again is there a easy way to take out the cluster?
hoffa65
319
416
Atlanta GA
Cluster should be easy to remove.
Pull head light switch to on position, look behind knob there is a tab, pull tab towards you/knob and pull knob off switch, remove trim insert , pulls off. Remove center trim pulls off.
Remove 4 lower surround screws 7mm, and 4 (i think upper surround screws. Remove surround.
Cluster has four 7 mm screws. Trick is the speedo cable, if you have CC disconnect it at the servo and push it thru firewall as you are pulling cluster out. There is a clip on the back holding speedo cable to cluster push tab on clip and pull cluster off cable, see pics
