Hi all, I'm in the process of buying an 80 Malibu wagon (v6, bench seat, not split) and wanted to know how are it is to swap a few parts. The first things I was looking to do was to swap gauges, and mount a floor shifter, and bucket seats.
I really like the look of the olds rally gauges, but i think that cluster is too wide to fit into a malibu, correct? Would it be better to go with a set from a monte ss? Im not a good electrician, so Im looking for more a plug a play. I can hook up sending units, and run a few wires, but not looking to solder circuit boards. Can I get the tach to work on the v6?
As for the floor shifter and buckets, I see plenty of threads on the bucket seats, but not many on floor shifters. Is it better to use a monte ss floor shifter vs a buick or olds or GP? Does it matter if its solid mechanical linkage, or can I use a cable? Will the shifter lever bolt in or do I make holes? Any helps or link works well for me.
Thanks for the help!
