Gbody bbc steel engine side mounts
Jame
41
8
I understand that there are car and truck engine side clam shell brackets. I dont know which I have. Part number on one is 140378 then a larger 78. Other only has a 34 stamped on it. I have no idea what they are out of just kept them for years. Have searched google cant find anything. I dont want to lower the engine to find it's wrong. Can some one positively identify them. I have enough in this build would like to use them if possible.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
the ones marked SBC are what you want
pagrunt
9,155
15,318
Elderton, Pa
As Turna said👆,use the original mounts that came wth your car if it is a SBC car. P/n 334970/stamped 334971.
Jame
41
8
I dont have any mounts with the car. Bought as a roller. Appears the mounts I do have are from a truck they dont look as short as the ones marked sbc. I know they came off a small block but are bigger I think than the ones in the pic. Sucks as I have these already. I don't want solid mounts I'm pretty sure or I'd buy the moroso brand.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
located?
39F
530
602
Pittsburgh PA
Short ones came in alot of cars and 4wd trucks , 2wd 73-87 had those tall mounts they don't work in our cars or anything else but 2wd 73-87 Chevy trucks and vans same year range + ,if your close to Pittsburgh I'd be more then willing to go you a set or two
  • Winner
Jame
41
8
I'm in mid Missouri lake ozarks. Thanks I'm sure I can get a set just have to go looking I guess. I didnt even know there were different ones till I started reading post
Ratchet
251
97
I have an extra pair of new SBC factory style mounts with the rubber inserts. I went with the steel mounts instead. PM me if you are interested.
Jame
41
8
Maybe I should go solid but I worry about shaking the car apart. It's a street strip deal but dont want to destroy the car driving it
