Gbody fan speed went out today while driving I check all my fuse they are good change the resistor and the relay and even clean the ground and still nothing . I have no speeds working blower won’t even come on . What should I do ?
I tell I was just riding with the ac blowing ice cold then it just went out no blower motorMine has done that as well in the recent past a couple times. Installed new relay, checked the resistor pack and fuse. All good. Then it just mysteriously started working again on its own. Maybe its in the climate control panel?
Where is the fuse locatedMine has done that as well in the recent past a couple times. Installed new relay, checked the resistor pack and fuse. All good. Then it just mysteriously started working again on its own. Maybe its in the climate control panel?
Red wire will be located where ?Check the 12 gauge red wire that powers it & look for any signs of electrical burns or even a melted plug connector.
